DIY Welding Table and Cart Ideas
I've got a little welding table atop a rolling tool chest that I threw together one afternoon. It has served me, but I'd like to do better at some point. Some of the features I'd incorporate into a new welding table/cart would be:
- Space for my Miller 180 Tig, a Miller 251 Mig, an ESAB plasma cutter, and my Oxy-Acetylene rig.
- Much thicker table surface. At least 1/2" steel and maybe even 1". Haven't decided whether to do the slotted clamping style or not.
- Slide out or tilt up plasma cutting rack.
- Receivers on the corners for accessories like a big vise and my chop saw. I might throw my tool grinder and disc sander on those receivers too.
- Centralized compressed air connection with hanging storage for air tools
- Outlets on the cart, die grinder and clamp racks.
- Rod storage on one side or the other as convenient.
- Bigger caster wheels so it's easier to roll a heavy cart over bumps.
- I'd definitely keep the tool cabinet in the core of the cart.
You can see all of those ideas and more in the photos below:
A little table I threw together in an afternoon. Love using rolling tool cabinets bought cheap at sales in these kinds of projects..
Neat pull out support for larger projects. Big vise is essential too. Lots of great fab projects like this on OffroadFabnet.com...
Neat idea for a plasma cutting cart. All the slag and dust funnels down to the bucket. Pirate4x4 is another great source for Fab projects...
Welding cart set up for clamping. Try Garage Journal for this project and more...
Tig Cart from MillerWelds forums is neat. Storage for the Tig, a homemade Tig water cooler, some rod, gas bottle, and the inevitable plastic box full of accessories.
Miller Dynasty Cart. These carts that match the welder's are sharp...
The pro-welders recommend thick plate on top. This table has 1" steel plate. See Practical Machinist for more, another great source of ideas...
Another very stout table, set up for clamping...
Every welder needs a bevy of angle grinders handy. I like hanging them right on the cart...
Lots to like about this Big Red Table. Thick metal top, Big Vise, Clamp Storage, Angle Grinder Storage, and look at those handy outlets for angle grinders and whatever else up under the table lip where they're protected. There's even flip up storage for the chop saw. Nice!
Outlets on the cart seem nice. If you've got multiple welders on the cart, providing them each with a 220 outlet on the cart that goes to a single connection the wall sounds handy too...
Gas tanks often consume quite a lot of space. This rig lays them in horizontally to recapture some space and keep the center of gravity low. Nice idea, though wrestling them back out of there for refill is probably painful.
Welding Table and Cart Ideas, Part 2
Forges
Grinders
Micarta
Sale Details
Featured Articles
CNC Router Cutter Types
Step and Servo Motor Sizing
Feeds and Speeds Guide
CNC Cutter Guide
Feeds and Speeds By Material
Sales, and Special Deals
GCode is complicated.
makes it easy.
Try It!
Feeds and Speeds:
Made Easy.
Try G-Wizard
