High Speed Machining
CNC Milling Feeds and Speeds Cookbook |
What is High Speed Machining?
There are many definitions for High Speed Machining (HSM). MMSOnline uses the tagline "Achieving high metal removal rates with quick milling passes" for the HSM zone on their site. Another very high tech definition of HSM is "Machining at the Resonant Frequency of the Machine," which goes to HSM techniques for selecting spindle speeds that minimize chatter. You'd think that the "High Speed" part of HSM would emphasize faster spindle speeds (Sandvik says HSM begins at 18000 rpm), but that interpretation is not universal as various shops discovered HSM techniques can work well even on slower spindles. Others argue that HSM is all about high material removal rates and leaving a surface finish good enough to call finished in one pass.
Whatever your pet definition of HSM may be, I like to look at HSM as a collection of techniques that "grew up" together in various aerospace machining operations such as Boeing's. It initially involved very high speed spindles but many of these techniques have since turned out to be applicable even for lower speed spindles.
Let's list off some of these techniques:
- HSM prefers to combine roughing and finishing passes. This is really only possible with higher speed spindles, so if you're trying to get by with a slower spindle, you'll have to split into the more traditional roughing and finishing passes. For the finishing pass, use tooling with as many flutes as possible. Finishing assumes all the inside corners have been roughed out, so there will be plenty of chip clearance available. The more flutes you have, the faster you can feed through the work for a given chipload. Hence, productivity goes up. The only reason to use fewer flutes is to improve chip clearance.
- HSM prefers smaller tooling that moves faster to very large slow moving tooling designed for "hogging". The smaller tooling saves on tool changes and makes it easier to achieve the ideal of eliminating the need for separate roughing and finishing passes.
- Take advantage of relatively low cut width 10-15% of tool diameter down to as little as 5% depending on where the sweet spot is for your spindle's max rpm and the SFM your tool can handle in the material. These low radial depths allow the tool better chip clearance and time to cool down in air, allowing for much higher productivity especially on harder materials. See the article on taking heat out of the cut for some idea of how this works. With low cut width, increase the cut depth. This allows more of the cutter's flute to come into play instead of just wearing out the bottom of the endmill.
- When spindle speed is a limiting factor, consider a high feed endmill. High feed endmills maximize axial chip thinning and allow much higher feedrates. Another popular roughing strategy when you don't have as much spindle speed as you'd like are as much machine rigidity is plunge roughing.
- Use CAM toolpath strategies that avoid the "Tyranny of the Corner" (see below for more on cutters). Such strategies include constant tool engagement angle strategies such as Volumill or Adaptive Clearing, Trochoidal Milling, and Slicing or Peeling of Corners.
- Since true HSM spindles offer a much broader range of rpms than conventional spindles, HSM often emphasizes choosing spindle speeds that maximize stable milling zones were chatter is much less likely. The same anti-chatter principles can be applied to lower spindle speeds, you simply have less rpm territory in which to find a stable zone that maximizes productivity. See our article on chatter for more on stable milling zones and the role of spindle rpm in chatter.
So there you have a small arsenal of strategies to choose from for increasing your productivity using ideas learned in the HSM world. Let's drill down a bit more on some of them.
Radial Chip Thinning
One of the first issues you will encounter when attempting to practice HSM with its low width of cut (or stepover) is radial chip thinning. We've written several articles on the subject, but for a quick overview, consider the following diagram:
View down the axis of the cutter shows how radial chip thinning works...
Note how shallow width of cut creates much thinner chips than a full deep cut. Any time your width of cut is less than half the cutter's diameter you need to start taking chip thinning into account. Failure to do so means you're not operating at the chiploads the manufacturer recommends. In the best case, you're leaving money on the table by not cutting as fast as you can. In the worst case, these too-thin chips lead to rubbing and burnishing, which heats the tool and wears it out dramatically more quickly.
The standard machinist's calculations for feeds and speeds don't account for chip thinning. You'll need a machinist's calculator like G-Wizard to come up with proper feeds and speeds where chip thinning is a factor.
The Tyranny of the Corner
Having mastered radial chip thinning as a refinement to your feeds and speeds, there is another challenge that awaits before you can properly master HSM techniques. It involves dealing with the Tyranny of the Corner. Any time your cutter moves from cutting in a straight line to changing directions in a corner, cutting forces and cutter engagement go way up. This is pretty easy to see from the diagram:
Entering a corner doubles the cutter engagement...
The arrow shows direction of cut as it proceeds from right to left into the corner. The diagram shows about 50% radial engagement. As you can see, moving into the corner doubles the tool engagement angle from about 90 degrees to 180 degrees. When that happens, cutter forces are doubled, the ability to clear chips is halved, and the amount of time a flute spends in air where it can release heat is also halved. This is a very hard thing for a cutter indeed, and the shock of it comes on very suddenly as the cutter doesn't have to move far to become fully embedded in the corner.
The practical upshot of all this is that manufacturer's recommended feeds and speeds for the tooling are based on the need to keep some safety margin for corners--quite a lot of safety margin based on what we're seeing. G-Wizard has a tool engagement angle calculator that lets you play with calculating tool engagement angles based on a description of the corner, the tool, and the desired cut. Here's a screen shot of the estimator:
G-Wizard's Tool Engagement Angle Calculator
In this case we're showing a 1/2" endmill making a cut with 10% radial engagement in a pocket with 90 degree corners. We can see that once the cutter hits the corner, the tool engagement angle, which is the number of degrees of the cutter's circumference engaged in cutting hits a peak of 126 degrees. For comparison, slotting is a 180 degree engagement angle and is about as bad as you can get (well, plunging is 360 degrees!).
For a long time the CNC world just dealt with the Tyranny of Corners. Some work was done on feedrate variation to slow the cutter as it went into the corner, but it is very hard to do this well. The corner engagement comes on so fast that the slow down has to extend long before the corner. This interferes with the ability to pick up much productivity by making the cutter run faster in straight lines. What if we could come up with a toolpath strategy that made sure the cutter never had to enter a corner in this way?
Referring back to our example from the screen shot above, 90 degree corners means TEA's (Tool Engagement Angles) of up to 126 degrees. Even though we have such a shallow cut (10% of diameter), that's a lot of engagement. But if we're cutting in a straight line with no corners, that TEA drops all the way down to just 36 degrees. Wow, imagine how much faster we can drive the cutter if we knew the engagement angle would never exceed 36 degrees? If were just a matter of the ratio of the TEA's (it's not!), we could go 3.5 times faster in the toolpath.
So how can we accomplish that?
Trochoidal Milling and Peeling or Slicing Corner Toolpaths
Some of the earliest attempts involve what is called Trochoidal Milling and Corner Peeling (or Slicing) toolpaths. Let's start with the Peeling. Imagine a corner like this:
Toolpath arcs to clean out a corner...
Assume that as the cutter is moving into a corner, it veers off along a series of arcs rather than ploughing deep into the corner. Each arc "Peels" another layer, and the depth of cut in the arcs is orchestrated to correspond to reduced cutter forces so we can go full speed through the peel. Can you see how Corner Peeling might get you through that corner faster than just ploughing in with the cutter?
Trochoidal Milling is similar in concept. Let's take the example of a slot, which is very demanding to cut and forces us to slow down. Suppose we have a cutter that is 1/4 the width of the slot in diameter. Now we have some room to work with. Let's treat it just like the corner peeling and perform a series of looping moves that slice off little peels of the slot rather than just digging straight in with a big cutter. That's Trochoidal Milling.
There are some variations, such as whether we use full circular loops or keep the retract side shorter by making little D's. The choice of the latter depends on your machine's acceleration capabilities. The D's demand a faster tighter machine while the loops can be a little more forgiving of slower machines.
The thing is, these sorts of cuts are capable of driving the tool enough faster that they can beat a big hogging cutter at material removal, especially if you don't have a big heavy machine with a lot of horsepower to back up the big hogging cutter.
What's the next level of refinement for this idea?
Constant Tool Engagement Angle Toolpaths
Trochoidal Milling and Corner Peeling are special cases. The Trochoids got created to deal with slot-like narrow pockets and of course Corner Peeling is for corners. Initially the CAM world wanted to solve HSM by taking the toolpaths they started with and using such techniques to chip away at their weak points. But before too long, folks started thinking of toolpaths that just never create a corner because they relied on completely new strategies. These are the Constant Tool Engagement Angle Toolpaths which go by many brand names such as Volumill, Dynamic Milling, or Adaptive Clearing. They all create elaborate looping toolpaths where the cutter veers away from over engagement just in the nick of time.
Here is a comparison of typical HSM and conventional toolpaths for the same pocket done in GibbsCAM:
Comparison of the same pocket done with HSM and conventional toolpaths in GibbsCAM as shown by the GWE CNC Simulator...
You can see there are sure a lot of sharp corners in a conventional toolpath. No wonder HSM can be so much faster!
High Speed Machining Feeds and Speeds
The question is, just how much faster can HSM be? In fact, what sorts of feeds and speeds should I be running with HSM?
For a long time there was not much help available for feeds and speeds. CAM providers published various accounts of how fast customers were cutting, but relating such anecdotes back to your own machining is problematic. If nothing else, you have no idea whether those numbers are baseline, or hand tuned numbers developed for manufacturing a particular part with a lot of trial and error. If they are the latter, they will likely fail if you plug them into a different part on a different machine with a slightly different HSM toolpath algorithm, and so on.
HSM is not something you can easily figure out with a few tables either. Fortunately, there are mathematical methods that work for it. After all, HSM is just physics and where there is physics some degree of predictability follows. The trick is to analyze the tool engagement angle being used for a particular cut (which can be derived by an HSM calculator from the cut width) and using that information together with a knowledge of how to calculate conventional speeds and feeds to "back out" the conservatism applied to conventional feeds and speeds due to corners. The two main effects that have to be accounted for are the chip clearance and the heating of the tool. Low TEA's give the tool a greater proportion of the rotational circle in which to cool down in air or via exposure to coolant.
G-Wizard has a built-in HSM calculator:
An HSM cut in mild steel...
The example cut being shown is a 1/2" endmill in mild steel, 10% radial engagement as we've been talking about, and a full 1" depth of cut. With an HSM toolpath that guarantees no corners will be cut, we can run 3936 rpm at 44.9 ipm feedrate. That's a 1.6 HP cut. Without HSM, the cut falls back to 1765 rpm at 8.8 ipm for a cut that's only 0.3 HP. The material removal rates for HSM are about 5x greater with HSM. You don't have to think to hard to realize why these HSM toolpaths have become almost indispensible for a lot of shops.
More HSM Links
When Spindle Speed is a Constraint
High Speed Machining's Origin Moment
Next Article: Dealing With Chatter When Milling
