G-Code and M-Code Reference List
for Turning
These are the common g-codes for CNC Lathes and turning. Code categories are the groupings for the g-code Wizard (type Ctrl+G for the Wizard). Function tells what the g-code does, Notes gives a little more information such as the parameters, and Tutorial is a link (if any) to a tutorial that uses G-Wizard Editor to teach how to use the g-code.
Code
Category
Function
Notes
Tutorials
  G00
Motion
Move in a straight line at rapids speed. XYZ of endpoint
G00 and MDI.
Linear Motion: G00 and G01
  G01
Motion
Move in a straight line at last speed commanded by a (F)eedrate XYZ of endpoint
G01 and MDI.
  G02
Motion
Clockwise circular arc at (F)eedrate
XYZ of endpoint
IJK relative to center
R for radius
Circular Arcs: G02 and G03
  G03
Motion
Counter-clockwise circular arc at (F)eedrate
XYZ of endpoint
R for radius
  G04
Motion
Dwell: Stop for a specified time.
P for milliseconds
X for seconds
Precise Timing and Speed: Dwell, Exact Stop, Backlash Compensation
  G09
Motion
Exact stop check   Precise Timing and Speed: Dwell, Exact Stop, Backlash Compensation
  G10
Compensation
Programmable parameter input
  G17
Coordinate
Select X-Y plane   CNC G-Code Coordinates
  G18
Coordinate
Select X-Z plane   CNC G-Code Coordinates
  G19
Coordinate
Select Y-Z plane   CNC G-Code Coordinates
  G20
Coordinate
Program coordinates are inches   G20 and G21: Unit Conversion
  G21
Coordinate
Program coordinates are mm   G20 and G21: Unit Conversion
  G27
Motion
Reference point return check   G28: Return to Reference Point
  G28
Motion
Return to home position   G28: Return to Reference Point
  G29
Motion
Return from the reference position   G28: Return to Reference Point
  G30
Motion
Return to the 2nd, 3rd, and 4th reference point   G28: Return to Reference Point
  G32
Canned
Constant lead threading (like G01 synchronized with spindle)
  G40
Compensation
Tool cutter compensation off (radius comp.)
  G41
Compensation
Tool cutter compensation left (radius comp.)
  G42
Compensation
Tool cutter compensation right (radius comp.)
  G43
Compensation
Apply tool length compensation (plus)
  G44
Compensation
Apply tool length compensation (minus)
  G49
Compensation
Tool length compensation cancel
  G50
Compensation
Reset all scale factors to 1.0
  G51
Compensation
Turn on scale factors
  G52
Coordinate
Local workshift for all coordinate systems: add XYZ offsets
  G53
Coordinate
Machine coordinate system (cancel work offsets)
  G54
Coordinate
Work coordinate system (1st Workpiece)
  G55
Coordinate
Work coordinate system (2nd Workpiece)
  G56
Coordinate
Work coordinate system (3rd Workpiece)
  G57
Coordinate
Work coordinate system (4th Workpiece)
  G58
Coordinate
Work coordinate system (5th Workpiece)
  G59
Coordinate
Work coordinate system (6th Workpiece)
  G61
Other
Exact stop check mode   Precise Timing and Speed: Dwell, Exact Stop, Backlash Compensation
  G62
Other
Automatic corner override
  G63
Other
Tapping mode
  G64
Other
Best speed path
  G65
Other
Custom macro simple call   Subprograms and Macros
  G70
Canned
Finish Turning Cycle
  G71
Canned
Rough Turning Cycle
G71: Rough Turning Cycle
G71 Type II: Rough Turning With "Pockets"
  G72
Canned
Rough Facing Cycle
  G73
Canned
Pattern Repeating Cycle
  G74
Canned
Peck Drilling Cycle
  G75
Canned
Grooving Cycle
  G76
Canned
Threading Cycle   G76 Lathe Threading Cycle
  G80
Canned
Cancel canned cycle
  G83
Canned
Face drilling cycle
  G84
Canned
Face Tapping cycle
  G86
Canned
Boring canned cycle, spindle stop, rapid out
  G87
Canned
Side Drilling Cycle
  G88
Canned
Side Tapping Cycle
  G89
Canned
Side Boring Cycle
  G90
Coordinate
Absolute programming of XYZ (type B and C systems)
  G90.1
Coordinate
Absolute programming IJK (type B and C systems)
  G91
Coordinate
Incremental programming of XYZ (type B and C systems)
  G91.1
Coordinate
Incremental programming IJK (type B and C systems)
  G92
Coordinate
Thread Cutting Cycle
  G92 (alternate)
Motion
Clamp of maximum spindle speed S
  G94
Motion
Endface Turning Cycle
  G96
Motion
Constant Surface Speed ON   G96: Constant Surface Speed
  G97
Motion
Constant Surface Speed Cancel   G96: Constant Surface Speed
G98
Motion
Linear Feedrate per Time
  G99
Motion
Feedrate per Revolution
M-Codes
Code
Category
Function
Notes
Tutorials
  M00
M-Code
Program Stop (non-optional)
  M01
M-Code
Optional Stop: Operator Selected to Enable
  M02
M-Code
End of Program
  M03
M-Code
Spindle ON (CW Rotation)   M03 and MDI.
  M04
M-Code
Spindle ON (CCW Rotation)
  M05
M-Code
Spindle Stop   M05 and MDI.
  M06
M-Code
Tool Change
  M07
M-Code
Mist Coolant ON   M07 and MDI.
  M08
M-Code
Flood Coolant ON   M08 and MDI.
  M09
M-Code
Coolant OFF   M09 and MDI.
  M13
M-Code
Spindle ON (CW Rotation) + Coolant ON   M13 and MDI.
  M14
M-Code
Spindle ON (CCW Rotation) + Coolant ON   M14 and MDI.
  M30
M-Code
End of Program, Rewind and Reset Modes
  M97
M-Code
Haas-Style Subprogram Call   Subprograms and Macros
  M98
M-Code
  M99
M-Code
Return from Subprogram   Subprograms and Macros
Bonus: Check Out our Other CNC Cookbooks for More In-Depth CNC Information!
If you're a CNC Beginnner, check out our CNC Beginner's Cookbook. It'll get you up to speed with a solid CNC foundation fast.
We also have Cookbooks for Feeds and Speeds, G-Code Programming, CNC Manufacturing and Shop Management, DIY CNC, and don't forget the CNC Cookbook Blog--with over 2 million visitors a year it's the most popular CNC blog by far on the web.
